TwinTurbo.NET: Nissan 300ZX forum - Sounds like it should be good as long as tensioner was set
JonnyZ(SoCal)
on August 03, 2012 at 3:26 PM
Re: He is talking about using a timing light to make sure your
posted by syphon0202
on August 03, 2012 at 03:10 PM
properly... but defiantly check your timing, also you should probably check your tps before you do the timing just to be on the safe side!
Good luck with your issues
300zx idling poorly after some work
syphon0202
10:05:44 08/03/12
Re: 300zx idling poorly after some work
Stokens (StoMoZTT)
11:04:52 08/03/12
Re: Re: 300zx idling poorly after some work
syphon0202
12:28:31 08/03/12
Before you changed the TB did you check the timing>>
ZUL8TR
13:25:23 08/03/12
Re: Before you changed the TB did you check the timing>>
syphon0202
14:16:14 08/03/12
JonnyZ(SoCal)
14:20:20 08/03/12
syphon0202
15:10:02 08/03/12
Sounds like it should be good as long as tensioner was set -
JonnyZ(SoCal)
15:26:02 08/03/12
Re: Sounds like it should be good as long as tensioner was set
syphon0202
15:30:22 08/03/12
That should be fine. (n/m)
Summeronthechain (MN)
09:12:58 08/06/12
Claification: I mean using a timing light before the TB >>
ZUL8TR
06:47:42 08/04/12
